PARAM, MBDH3D
Bulk Data Entry Choose the type of the results output to the .h3d file for MBD analyses.
Parameter Values Description
MBDH3D <NODAL, MODAL, BOTH, or NONE> This parameter controls the type of results output to the .h3d results format for MBD analyses.
NODAL
Nodal based results are output to the .h3d results file.
MODAL
Modal based results are output to the _mbd.h3d results file.
BOTH (Default)
Nodal results are output to the .h3d results file and modal results are output to the _mbd.h3d file.
NONE
MBD results are not output to either the .h3d or _mbd.h3d results file.
  1. If the HyperMesh output format is requested, nodal based results will be output to the .res file, regardless of this parameter setting.
