PARAM, NLRUN
Bulk Data Entry This parameter controls if geometric nonlinear analysis subcases run automatically after these subcases in Bulk Format are converted into Block Format.
Note: Obsolete parameter - use RADPRM, NLRUN.
Parameter Values Description
NLRUN
<YES, NO>
YES (Default)
Geometric nonlinear analysis subcases run automatically after conversion.
NO
Geometric nonlinear analysis subcases do not run automatically after conversion.
