PARAM, NPRBAR
Bulk Data Entry Controls the number of the output INFORMATION #741 for RBAR element.
Parameter Values Description
NPRBAR <INTEGER>
Default = 3
Controls the number of the output INFORMATION #741 for RBAR elements.
Example of INFORMATION #741:
*** INFORMATION # 741
No need to constrain the rotational dof of this dependent grid.
RBAR element id = 20436260
independent grid id = 20374048
dependent grid id = 20367448
This is because there isn't any stiffness and load on the rotational dof of the dependent grid.
