PARAM, OGEOM
Bulk Data Entry Outputs model data to the OUTPUT2 results file.
Parameter Values Description
OGEOM <YES, NO> Controls the output of model (geometry) data to the .op2 file. This functionality is also controlled by the MODEL/NOMODEL option on the OUTPUT, OP2 I/O option, but this parameter setting will override the OUTPUT, OP2 setting.
YES (Default)
Will output model data to the .op2 file.
NO
Will not output model data to the .op2 file.
