PARAM, OP2GM34
Bulk Data Entry Controls the output of GEOM3 and GEOM4 data blocks to the .op2 file.
Parameter Values Description
OP2GM34 <TRUE, FALSE> Controls the output of GEOM3 and GEOM4 data blocks to the .op2 file if PARAM, POST, -1 is specified.
TRUE (Default)
Outputs GEOM3 and GEOM4 data blocks to the .op2 file, if PARAM, POST, -1 is specified.
FALSE
Does not output GEOM3 and GEOM4 data blocks to the .op2 file.
