PARAM, OSTTSPRT
Bulk Data Entry One-Step Transient Thermal Stress Analysis solution and convergence information is output in the .out file. Nonlinear OSTTS is performed by generating internal static subcases at each output time step.
Parameter Values Description
OSTTSPRT <YES, NO>
YES
Will print solution information for these subcases with internally generated subcase ID’s.
NO (Default)
Nonlinear OSTTS convergence information is not printed to the .out file.
