PARAM, PEACTDMG
Bulk Data Entry Controls the output of the .eactdmg file for Pseudo Damage method in fatigue analysis.
Parameter Values Description
PEACTDMG <YES, NO>
  1. The default is YES when the parameter is not present in the deck.
  2. This parameter cannot be specified in the input deck without a value. OptiStruct will error out in this case.
This file contains element sets for which actual damage was calculated in each fatigue subcase.
YES (Default)
The .eactdmg file is output.
NO
The .eactdmg file is not output.
