PARAM, PRTNORM
Bulk Data Entry Defines the maximum number of contributions printed for each norm response under the norm response itself in the .out file for an Optimization run.
Parameter Values Description
PRTNORM <Integer > 0>
Default = 10
The top PRTNORM number of contributions (element ID, response value, and constraint violation) for each norm response are printed, with a default of 10.
