PARAM, SNAPTHRU
Bulk Data Entry This parameter controls the output of the force-deflection curve in geometric nonlinear analysis.
Note: Obsolete parameter - use RADPRM, SNAPTHRU.
Parameter Values Description
SNAPTHRU YES, NO PARAM, SNAPTHRU controls the output of the force-deflection curve in geometric nonlinear analysis.
YES
The converter will generate rigid bodies internally and output the time history for rigid body forces in the Time-History (TH) file. This is valid only when grids are defined on XHIST Bulk Data Entry with TYPE = GRID and ENTRY=DEF simultaneously. The force-deflection curve can be cross plotted with the grid displacements and corresponding rigid body forces in HyperGraph.
NO (Default)
Output of the force-deflection curve is not requested and the internal rigid bodies are not generated.
