PARAM, TPS
Bulk Data Entry Activates fast transient response analysis (only shell stress results output).
Parameter Values Description
TPS <YES, NO> PARAM, TPS may be used with transient response analysis. When only shell stress results are required from a transient response analysis, significant speed improvements in run time can be obtained with the use of this parameter.
YES (Default)
Fast transient response analysis is activated - only shell stress results output may be requested in this case. That is, no displacement results are output.
NO
Normal transient response analysis is performed.
