PARAM, UHT
Bulk Data Entry Outputs the UHT data block.
Parameter Values Description
UHT <YES, NO>
YES
The UHT data block is output as a separate OP2 file <filename>.modalsol.op2.
NO (Default)
The UHT data block is not output.
  1. This parameter is currently supported only for Modal Transient Analysis.
