PARAM, VREF
Bulk Data Entry Used in aeroelastic flutter analysis to specify a factor to divide the velocities.
Parameter Values Description
VREF Value of the factor
Default = 1.0 (Real > 0)
The velocities are divided by the value specified in this parameter to convert units or to compute flutter indices.
