PBEAMX
Bulk Data Entry Defines additional BEAM properties for geometric nonlinear analysis.
PBEAMX PID ISMSTR ISTRAIN DM DB
PID Property identification number of the associated PBEAM and PBEAML. 1
No default (Integer > 0)
ISMSTR Small strain formulation flag.
1
Small strain from time =0 If the small strain option is activated (ISMSTR = 1), the strain and stress are engineering strain and stress; otherwise they are true strain and stress.
2 (Default)
Full geometric non-linearity.
(Integer)
ISTRAIN Shear in beam formulation flag.
ON (Default)
OFF
DM Beam membrane damping.
Default = 0.0 (Real ≥ 0.0)
DB Beam bending damping.
Default = 0.01 (Real ≥ 0.0)
  1. The property identification number must be that of an existing PBEAM Bulk Data Entry. Only one PBEAMX property extension can be associated with a particular PBEAM.
  2. PBEAMX is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
  3. This card is represented as an extension to a PSOLID property in HyperMesh.
