OS-E: 0305 Preloaded Modal Frequency Response Analysis
A Preloaded Modal Frequency Response Analysis of folding blade shaft which is mounted on the bolted flange.
Figure 1. FE Model, Along with the Results from all Three Subcases
Model Files
The model file used in this example includes:
PRELOAD_NLSTAT_MFRF.fem
Model Description
The operational loading involves three steps (or subcases).
In the first subcase a pre-tensioning force of 3.5E3 Newton’s is applied on 3 bolts that are connected to the flange. In the second subcase a Clamping pressure of 1E4 MPA is applied on the flange and 1MPA is applied on the folding blades. In the third subcase a tip load is applied on the flat surface of the blade.
Case 1
Nonlinear Static Analysis
Bolt Pretension
Case 2
Pressure Load with CNTNLSUB and STATSUB(PRETENS)
Case 3
With STATSUB (PRELOAD)
In Modal Frequency Response Analysis, the modal solution is performed using AMSES.
FE Model
Bolts
CBEAM
CHEXA
Flange and Blade
CTETRA
The linear material properties are:
MAT1
Young’s Modulus
2.1E5
Poisson's Ratio
0.3
Initial Density
7.8E-9
Results
The displacement results on the bolts for subcase 1 and read the .PRET file and review the results. In Figure 2, observe the displacement results snapshot from all the 3 subcases.
In subcase 3, the preloading is captured by a geometric stiffness matrix K G MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaC4samaaBa aaleaacaWGhbaabeaaaaa@37C2@ which is based on the stresses of the preloading nonlinear static subcase 2. In prestressed analysis, this geometric stiffness matrix is augmented with the original stiffness matrix K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaC4saaaa@36CA@ of the (unloaded) structure.
In this model since there is contact, the contact status can be carried over from the preloading subcase 2 to the preloaded subcase 3.
Figure 2. FE Model, along with the Results from all Three Subcases
For comparison study, when this example model is run with and without STATSUB (Pre-Load) in subcase 3, notice the different in the frequencies of the eigenvector in the .out files. In the Modal Frequency Response Analysis without Preload you have rigid body modes as the contact between the bolts and the flange has not been established.
Figure 3. Difference in Frequencies of Eigenvector
Also, when you plot the MFREQ results at frequency 300Hz, notice the difference between the mode shape.
Figure 4. Modal frequency response plots
