PRETPRM, INILOAD
Bulk Data Entry Defines the handling of initial loading conditions on pretension sections that have been defined, but not yet explicitly loaded via PRETENSION command.
Parameter Values Description
INILOAD <ZEROF, ZEROA>
ZEROF (Default)
In a pre-tensioning subcase, for any pretension section without pretension load, zero force will be applied. This is equivalent to setting zero PTFORCE.
ZEROA
Zero relative deformation is enforced on the pretension section defined above. This is equivalent to setting zero PTADJST.
