.prop file
The .prop file is an OptiStruct ASCII format result file.
File Creation
This file is output when sizing optimization is performed. Creation of this file is controlled by the PROPERTY I/O Option.
File Contents
Result Description
Property definition The property definitions, for those properties that were affected in the sizing optimization, used for the final iteration of the optimization.
File Format
The format for the property output is the same as for the Bulk Data Entries.
