PSURF
Bulk Data Entry Defines properties of a contact surface.
PSURF PID EDGECRIT
PID Property identification number.
No default (Integer > 0)
EDGECRIT Activate edges on the surface that have feature angle greater than or equal to the specified value.
No default (0.0 ≤ Real ≤ 180.0)
  1. This property can be referenced on the CONTACT Bulk Data Entry.
