QBDYLIB
Bulk Data Entry Defines the external function to be called to calculate time and temperature-dependent Uniform Heat Flux values.
QBDYLIB SID GROUP FUNCT
Definition
SID Load set identification number that matches the identification number on the QBDY1 entry.
No default (Integer > 0)
GROUP Defines the shared/dynamic library to be used.
It refers to an existing LOADLIB entry in the input deck.
No default (Character)
FUNCT Defines the external function to be used.
  1. The load set identification number (SID) must match the corresponding identification number on the QBDY1 entry.
