RADBC
Bulk Data Entry Defines the radiation boundary conditions and identifies CHBDYE entries for heat transfer analysis via radiation.
RADBC NODAMB FAMB CNTRLND EID1 EID2 EID3 EID4 EID5
  EID6 EID7 etc.
RADBC 23 0.9 334 12 34 33
NODAMB Ambient point for radiation exchange identification number.
No default (Integer > 0)
FAMB Radiation view factor between the face and ambient point.
No default (Real ≥ 0)
CNTRLND Control point for radiation boundary conditions.
= 0
q = σ ⋅ FAMB ⋅ ( ε e ( T e + T a b s ) 4 − α e ( T a m b + T a b s ) 4 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyCaiabg2 da9iabeo8aZjabgwSixlaabAeacaqGbbGaaeytaiaabkeacqGHflY1 daqadaqaaiabew7aLnaaBaaaleaacaWGLbaabeaakmaabmaabaGaam ivamaaBaaaleaacaWGLbaabeaakiabgUcaRiaadsfadaWgaaWcbaGa amyyaiaadkgacaWGZbaabeaaaOGaayjkaiaawMcaamaaCaaaleqaba GaaGinaaaakiabgkHiTiabeg7aHnaaBaaaleaacaWGLbaabeaakmaa bmaabaGaamivamaaBaaaleaacaWGHbGaamyBaiaadkgaaeqaaOGaey 4kaSIaamivamaaBaaaleaacaWGHbGaamOyaiaadohaaeqaaaGccaGL OaGaayzkaaWaaWbaaSqabeaacaaI0aaaaaGccaGLOaGaayzkaaaaaa@5D96@
> 0
q = σ ⋅ FAMB ⋅ u C N T R L N D ⋅ ( ε e ( T e + T a b s ) 4 − α e ( T a m b + T a b s ) 4 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyCaiabg2 da9iabeo8aZjabgwSixlaabAeacaqGbbGaaeytaiaabkeacqGHflY1 caWG1bWaaSbaaSqaaiaadoeacaWGobGaamivaiaadkfacaWGmbGaam OtaiaadseaaeqaaOGaeyyXIC9aaeWaaeaacqaH1oqzdaWgaaWcbaGa amyzaaqabaGcdaqadaqaaiaadsfadaWgaaWcbaGaamyzaaqabaGccq GHRaWkcaWGubWaaSbaaSqaaiaadggacaWGIbGaam4Caaqabaaakiaa wIcacaGLPaaadaahaaWcbeqaaiaaisdaaaGccqGHsislcqaHXoqyda WgaaWcbaGaamyzaaqabaGcdaqadaqaaiaadsfadaWgaaWcbaGaamyy aiaad2gacaWGIbaabeaakiabgUcaRiaadsfadaWgaaWcbaGaamyyai aadkgacaWGZbaabeaaaOGaayjkaiaawMcaamaaCaaaleqabaGaaGin aaaaaOGaayjkaiaawMcaaaaa@66C8@
Default = 0 (Integer ≥ 0)
EIDi CHBDYE element identification number(s). Keywords THRU and BY are available for alternate format listing in ascending order of EIDi.
  1. For a Heat Transfer Analysis via Radiation, PARAM,TABS can be used to define the absolute temperature scale, and PARAM,SIGMA is used to specify the Stefan-Boltzmann constant. Additionally, a RADBC entry can be used to define radiation boundary conditions. Both RADM and RADBC entries are referenced on the CHBDYE Bulk Data Entry.
  2. NODAMB is treated as a black body with its own ambient temperature for radiation exchange between the surface element and space.
