RADPRM, RBE2RBD
Bulk Data Entry The RBE2 is converted to /RBE2 by default in explicit dynamic analysis.
| Parameter | Values | Description |
| RBE2RBD | <YES,
NO> Default = NO |
This parameter can be used
to convert RBE2 to /RBODY,
instead of /RBE2. Note: RBE2 can be converted to
/RBODY only if all six degrees-of-freedom
of the depdendent nodes are dependent on the independent node.
Otherwise, the solver errors out when RBE2RBD
= YES. If the independent node of the
RBE2 is connected to other elements or in
the case of hierarchical RBE2's,
RADPRM, RBE2RBD
activation is not recommended.
