RVDOF1
Bulk Data Entry Defines the degrees of freedom where the residual vectors are to be calculated.
RVDOF1 C G1 G2 G3 G4 G5 G6 G7
  G8 G9 G10 etc.
RVDOF1 123 34 88 4 12 19 7 70
  1234 65
Alternate Format and Example
RVDOF1 C G1 "THRU" G2
RVDOF1 123456 88 THRU 207
Ci Component numbers.
(Integer zero or blank for scalar points, or up to 6 unique digits (0 < integer ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.)
Gi Grid or scalar point identification numbers.
(Integer > 0, for THRU option, G1 < G2)
  1. If the alternate format is used, all points in the sequence G1 through G2 are not required, but there must be at least one boundary degree of freedom for the model, or a fatal error will result. Any grids implied in "THRU" that do not exist will collectively produce a warning message, but will otherwise be ignored.
