SEQSET1
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis (Alternate Format).
SEQSET1 SEID C G1 G2 G3 G4 G5 G6
  G7 G8 etc
Alternate Format
SEQSET1 SEID C G1 THRU G2
SEQSET1 12 123456 2 45 923 1344 3 922
  23 26
SEID Superelement identification number.
No default (Integer ≥ 0)
C Component numbers.
Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.
Gi Grid or Scalar Point identification numbers (should be an external point).
Default = Blank (Integer > 0, or THRU)
  1. Degrees-of-freedom on SEQSET entry should not be used on any other Superelement.
  2. If the THRU option is used, then G1 should be less than G2.
