SET1
Bulk Data Entry Defines a list of structural grid points or element identification numbers.
SET1 SID ID1 ID2 ID3 ID4 ID5 ID6 ID7
  ID8 etc.
Example 1
SET1 3 31 62 93 124 16 17 18
  19
Example 2
SET1 6 29 32 THRU 50 61 THRU 70
  17 57
SID Unique identification number.
(Integer > 0)
IDi List of structural grid point or element identification numbers.
(Integer > 0 or "THRU, ENDTHRU, and EXCEPT"; for the "THRU" option, ID1 < ID2)
  1. All set ID's must be unique for all Bulk Data SET, SET1, SET3, and solution control SET data.
  2. When using "THRU," missing ID's are ignored.
  3. This card is represented as a set in HyperMesh.
