SETREE
Bulk Data Entry Defines the Superelement Tree for One-Step Superelement Analysis.
SETREE SEID SEUP1 SEUP2 SEUP3 SEUP4 SEUP5 SEUP6 SEUP7
  SEUP8 SEUP9 etc
SETREE 7 333 12 556 99 5
SEID Superelement identification number.
No default (Integer ≥ 0)
SEUPi Superelements upstream of SEID identification numbers.
Default = Blank (Integer > 0)
  1. SEUPi fields should be unique across all SETREE entries.
