SLOAD
Bulk Data Entry Defines concentrated static loads on scalar, grid or fluid points.
SLOAD SID S1 F1 S2 F2 S3 F3
SLOAD 21 3 4.5 4 29.0
SID Load set identification number.
No default (Integer > 0)
S# A scalar, grid or fluid point identification number.
F# Load magnitude.
No default (Real)
  1. SLOAD may be referenced as the EXCITEID on an ACSRCE Bulk Data Entry.
  2. Up to three loads may be defined on a single entry.
