SPCP
Bulk Data Entry Defines the flow pressure boundary conditions for Darcy Flow Analysis.
SPCP SID G D G D G D
SPCP 2 32 0.0 33 0.0 34 0.0
SID Flow pressure boundary condition set identification number.
(Integer > 0)
G Grid identification number.
(Integer > 0)
D Enforced flow pressure value for grid designated by G.
No default (Real)
  1. The SPCP Bulk Data Entry should be referenced by a SPCP Subcase Entry to define Flow Pressure boundary conditions and activate Darcy Flow Analysis. An SPCP Bulk/Subcase Entry pair is mandatory to activate flow analysis in steady-state heat transfer analysis. The INLTVEL Bulk/Subcase pair is optional.
  2. For inlet flow conditions, there are two options:
    • Use SPCP Bulk/Subcase data to define both inlet and outlet flow pressures, leading to a definition of flow pressure differential.
    • Use SPCP Bulk/Subcase data to define outlet pressure and use the INLTVEL Bulk/Subcase pair to define the inlet velocity.
  3. Continuation lines are not supported for SPCP Bulk Data Entry.
