Bulk Data Entry Defines values of parameters used during the
CWELD and CSEAM connectivity search.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| SWLDPRM |
PARAM1 |
VAL1 |
PARAM2 |
VAL2 |
PARAM3 |
VAL3 |
PARAM4 |
VAL4 |
PARAM5 |
VAL5 |
etc. |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| SWLDPRM |
GSPROJ |
15.0 |
PRTSW |
1 |
Alternate Format
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| SWLDPRM |
PARAM1 |
VAL1 |
PARAM2 |
VAL2 |
CTYPE1 |
PARAM3 |
VAL3 |
PARAM4 |
VAL4 |
CTYPE2 |
PARAM5 |
VAL5 |
PARAM6 |
VAL6 |
PARAM |
VAL7 |
etc. |
Example (Alternate Format)
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
| SWLDPRM |
GSPROJ |
15.0 |
PRTSW |
1 |
CWELD |
GSMOVE |
2 |
NREDIA |
3 |
PROJTOL |
0.03 |
CSEAM |
CNRAGLI |
150.0 |
GSPROJ |
20.0 |
SHOWAUX |
1 |
| Field |
Contents |
SI Unit Example |
| PARAM# |
Name of parameter. |
| VAL# |
Value of
parameter. |
| CTYPE |
Connector type keyword to
control the element specific parameters. Parameters following a
keyword will only be applied to the element type specified by the
keyword. Supported connector types: CWELD
or CSEAM
While textual values are recommended for clarity, their integer equivalents will also
be read. The available parameters and their values are listed below.
- Parameter
- Value
- SWLDPRM, ASCHAUX
- <NO, YES>
- Default = NO
- SWLDPRM, CHKRUN
- <NO, 0, YES, or
1>
- Default = NO
- SWLDPRM, CNRAGLI
- 90.0 ≤ Real ≤ 160.0 or -1.0
- Default = 160.0
- SWLDPRM, CNRAGLO
- 0.0 ≤ Real ≤ 90.0 or -1.0
- Default = 20.0
- SWLDPRM, GMCHK
- <NO, 0, YES,
1, FULL, or 2>
- Default = NO
- SWLDPRM, GSMOVE
- Integer ≥ 0
- Default = 0
- SWLDPRM, GSPROJ
- Default = 20.0
- SWLDPRM, GSTOL
- Real ≥ 0.0
- Default = 0.0
- SWLDPRM, NREDIA
- 0 ≤ Integer ≤ 4
- Default = 0
- SWLDPRM, PATEXT
- <YES, NO>
- Default = NO
- SWLDPRM, PROJTOL
- 0.0 ≤ Real ≤ 0.5
- Default = 0.05
- SWLDPRM, PRTSW
- <NO, 0, YES, or
1>
- Default = NO
- SWLDPRM, SHOWAUX
- <NO, 0, YES, or
1>
- Default = 0
- The SWLDPRM entry
changes the default settings of parameters for the CWELD and
CSEAM connectivity entries. None of the parameters of this
entry are required. The default settings should be changed only for diagnostic and
debug purposes. Only one SWLDPRM entry is allowed in the Bulk
Data section.
- Connectivities are created for the
CSEAM element and for the CWELD element
with PARTPAT, ELPAT, ELEMID and
GRIDID formats. With the parameters on this entry, you can
debug and alter the search algorithm which creates these connector elements.
- Before the presence of any keyword of the
connector, that is CWELD and CSEAM, the
parameter set on the entry will be regarded as "global", and it will be applied to
all of the connector elements, unless it only serves a specific type of
connector.
- Any parameter following a connector
keyword will only be applied to the element type specified by the keyword until the
presence of another keyword.
- Blank fields are allowed in this entry.
However, blank fields are not allowed between the parameter name and the
corresponding parameter value or between the connector keyword and the parameter
name followed. If the parameter name or the connector keyword is located just before
the continuation field, then the following content must be placed in the first field
after the continuation marker.
- Further detailed information about the
individual connector elements can be found in the pertinent CWELD and CSEAM Bulk Data Entries.
- Some of the above parameters apply only
to selected connector types. Such information is provided within the detailed
description of individual parameters.
