SWLDPRM, PROJTOL
Bulk Data Entry Tolerance to accept the projected points (from GS for CWELD and from GS/GE for CSEAM) if the computed coordinates of the projection point lies outside the shell element but is located within PROJTOLx (dimension of the shell element).
Parameter Values Description
PROJTOL 0.0 < Real < 0.5
Default = 0.05
PROJTOL is only activated when a search without PROJTOL finds no candidate shell to build connectivity for a connector element. This prevents the search from picking the wrong shell element in cases when PROJTOL is not needed.
