TABFAT
Bulk Data Entry Defines y values of each point on the loading time history.
TABFAT ID y1 y2 y3 y4 y5 y6 y7
    y8 etc. etc.
TABFAT 1 0.000 -0.601 0.968 0.515 -0.263 -0.090 -0.582
    -0.592 -0.877 -0.726 0.297 -0.899 -0.899 -0.165
    0.907 0.936 -0.308 -0.308 -0.689 0.592 0.609
    -0.600 -0.492 -0.492 -0.224
ID Unique identification number.
No default (Integer > 0)
y# Y value of each point on the loading time history curve.
No default (Real)
  1. The TABFAT ID may be referenced by a FATLOAD definition.
  2. This card is represented as a load collector in HyperMesh.
  3. Prior to OptiStruct version 11.0, TABFAT was named TABLEFAT.
