OS-E: 0885 Bore Distortion Responses
Topology optimization of a cylinder block with a bore will be performed. The cylinder block is modeled using first order solid (Hexa and Penta) elements.
Figure 1. FE Model with Loadcases and Loadstep
Model Files
The model file used in this example includes:
bore_deformation_optimization.fem
Model Description
- Objective
- Minimize the maximum bore distortion
- Constrains
- Minimize 30% of the volume and the compliance
- Design Variables
- Topology Design Variable
Results
Figure 2. Average Element Density of the Optimized Model
Z-Depth | Order 0 | Order 1 | Order 2 | |||
Baseline | Final | Baseline | Final | Baseline | Final | |
0 | -2.73E-05 | -2.84E-03 | 3.99E-02 | 3.43E-02 | 1.87E-02 | 3.41E-02 |
5 | -2.67E-05 | -3.54E-03 | 4.00E-02 | 3.39E-02 | 1.83E-02 | 3.43E-02 |
10 | -2.73E-05 | -2.83E-03 | 3.99E-02 | 3.43E-02 | 1.87E-02 | 3.41E-02 |
0 | -1.79E-03 | 2.07E-02 | 1.14E-02 | 2.27E-03 | 1.10E-02 | 3.42E-02 |
5 | -1.79E-03 | 2.09E-02 | 1.14E-02 | 2.63E-03 | 1.08E-02 | 3.43E-02 |
10 | -1.79E-03 | 2.07E-02 | 1.14E-02 | 2.28E-03 | 1.10E-02 | 3.42E-02 |
