OS-E: 0850 V-Bracket using RADOPT
Demonstrates topology optimization of a V-bracket with RADOPT technique, using OptiStruct. RADOPT is Radioss optimization using OptiStruct. The equivalent static load method (ESLM) is used to perform the optimization run here.
Figure 1. FE Model
Model Files
The model files used in this example include:
  • hook_opt_0001.rad
  • hook_opt_0000.rad
  • hook_opt.rad
Model Description
Conduct a topology optimization of the V-bracket which is undergoing a compression loading (force applied in negative Y-direction), and the design space (yellow) in Figure 1.
FE Model
Elements Types
HEXA
RBE2
The linear material properties are:
MAT1
Young’s Modulus
2.1E5 MPA
Poisson's Ratio
0.3
Density
7.9E-9
Results
Based upon these findings, a topology optimization, the Design Objective and Design Constraint satisfied (Figure 2) and also design change on the V-bracket in Figure 3 are found.
Figure 2. Design Objective and Design Constraint
Figure 3. Element Density Results
