.trf file
An ASCII format results file which contains Bulk Data of loads from Aeroelastic Analysis results.
File Creation
This file is always created when the TRIMF I/O Entry is specified for an Aeroelastic Trim analysis run.
File Contents
This file provides the output of trim loads from a tatic Aeroelastic Analysis as FORCE/MOMENT Bulk Data Entries.
File Format
The file contains trim loads from a static aeroelastic analysis as FORCE/MOMENT Bulk Data Entries and is printed by default in Fixed format.
An example printing of the .trf file is:
$ TRIM CASE:        1
$ ELASTIC (AERODYNAMIC + APPLIED - INERTIAL) LOADS
FORCE          110000001       0     1.0 0.0E+00 0.0E+00-8.9E-02
FORCE          110000002       0     1.0 0.0E+00 0.0E+00-7.9E-02
FORCE          110000003       0     1.0 0.0E+00 0.0E+00-8.7E-02
FORCE          110000004       0     1.0 0.0E+00 0.0E+00-9.2E-02
FORCE          110000005       0     1.0 0.0E+00 0.0E+00-9.1E-02
FORCE          110000006       0     1.0 0.0E+00 0.0E+00-8.6E-02
FORCE          110000006       0     1.0 0.0E+00 0.0E+00-7.9E-02
FORCE          110000007       0     1.0 0.0E+00 0.0E+00-1.7E-01
FORCE          110000009       0     1.0 0.0E+00 0.0E+00-8.7E-02
FORCE          110000010       0     1.0 0.0E+00 0.0E+00-7.9E-02
FORCE          110000011       0     1.0 0.0E+00 0.0E+00-8.9E-02
