TRIM
Subcase Information Entry Used to select trim variable constraints by referencing a corresponding TRIM Bulk Data Entry.
TRIM = option
Argument Options Description
option <ID>
No default
ID
Set identification number of a TRIM Bulk Data Entry.
  1. Aerodynamic extra points (trim variables) not constrained by a TRIM Bulk Data Entry will be free during the static aeroelastic response solution.
