TSTRU
Subcase Information Entry The TSTRU command can be used to assign a temperature set identification number to the resulting nodal temperatures of a steady-state heat transfer analysis or the last time step of a transient heat transfer analysis.
TSTRU = option
Argument Options Description
option <SID>
Default = Subcase ID
SID
This is a temperature set identification number. It may be referenced from a static analysis subcase, in which case the resulting nodal temperatures of a steady-state heat transfer analysis or the last time step of a transient heat transfer analysis are considered as applied loads for the static analysis.
  1. TSTRU is only valid in a heat transfer subcase.
  2. If TSTRU does not explicitly appear in a heat transfer subcase, the Subcase ID is used as the default.
  3. A temperature set from a heat transfer analysis will override any temperature set defined by the Bulk Data Entries TEMP or TEMPD.
