2D and 3D Analysis Options
  2D 3D
Quad
Solid
Shell 4 Node
Shell 3 Node
Truss
Beam
Spring
Concentrated load
Pressure load
Initial velocity
Fixed velocity
Gravity
Interface Type 1, 2, 3, and 5 all
Rigid wall Type 1 all
Rigid body
Added mass
Section
Cylindrical joint
Monitored Volumes
Property Type 14
/DFS/DTPLAN, /DFS/DETPOIN, /DFS/DETLINE, /DFS/LASER, /DFS/WAV_SHA
/UPWM
/UPWIND
/ALE/BCS
/ALE/GRID/DISP, /ALE/GRID/DONEA,
/ALE/GRID/SPRING,
/ALE/GRID/STANDARD, /ALE/GRID/ZERO
/ALE/CLOSE
/ALE/MAT
/ALE/LINK/VEL
/AMS
/EULER/MAT
✓ : yes
blank : no
