Radioss
Radioss
2022
  1. Home
  2. User Guide
  3. Explicit Structural Finite Element Analysis
    In this section, available explicit features for different explicit analyses are presented.
  4. Connections
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Verification Problems
  • Frequently Asked Questions
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
Radioss
2022
Radioss
  • What's New
    View new features for Radioss 2022.
  • Overview
  • Tutorials
  • User Guide
    • Run Radioss
      The Radioss solver can be executed using different methods described here.
    • Explicit Structural Finite Element Analysis
      • Time Step
        An explicit is solved by calculating results in small time increments or time steps. The size of the time step depends on many factors but is automatically calculated by Radioss.
      • Finite Elements
      • Modeling Tools
      • Materials
        Different material tests could result in different material mechanic character.
      • Failure
      • Composites
        Composite materials consist of two or more materials combined each other. Most composites consist of two materials, binder (matrix) and reinforcement. Reinforcements come in three forms, particulate, discontinuous fiber, and continuous fiber.
      • Connections
        • Spotweld (Bolt or Adhesive Connection)
        • Bolt Modeling for Crash
      • Kinematic Constraints
        In Radioss, a kinematic condition is a nodal constraint applied to a set of nodes.
      • Interfaces
        Several interfaces are available in Radioss, this section deals with contact interfaces only. Each interface is distinguished with a type number.
      • Loads
      • Airbag Modeling
        Airbags are modeled as monitored volumes /MONVOL in several different ways.
      • Debugging Guidelines
      • Appendix
    • Implicit Structural Finite Element Analysis
    • Fluid and Fluid-Structure Simulation
      In this section, fluid and fluid-structure simulation is presented.
    • Smooth Particle Hydrodynamics (SPH)
      The Smooth Particle Hydrodynamics method formulation is used to solve the equations of mechanics, when particles are free from a meshing grid.
    • Multi-Domain Technique
      The objective of the Multi-Domain technique (also referred to as RAD2RAD) is to optimize the computing performances of large scale Radioss models.
    • Design Optimization
      Optimization in Radioss was introduced in version 13.0. It is implemented by invoking the optimization capabilities of OptiStruct and simultaneously using the Radioss solver for analysis.
    • Error Message Database
      This section is comprised of error messages in ascending numerical order.
    • Engine Error Messages
    • Warning Message Database
      This section is comprised of warning messages in ascending numerical order.
  • Reference Guide
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
View All Altair Simulation Help
Radioss
Radioss
2022
  1. Home
  2. User Guide
  4. Connections
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
Connections
