Engine Input
The Radioss is executed in two steps:
  1. The Starter
  2. The Engine
The Starter reads a Runname_0000.rad file that contains the model definition. The Starter diagnosis possible errors in the models and outputs a binary restart file.
The Engine executes the actual computation. It expects the binary file produced by the Starter plus a Runname_run#.rad input file in Block Format. The Engine Input describes the case control. The Engine produces output files for animation, plotting (time history), and restart.
Below is an alphabetical list of the Engine keywords.
/@TFILE
/@TFILE/Keyword2
/ABF
/ADYREL
/ALE/GRID/DISP
/ALE/GRID/DONEA
/ALE/GRID/SPRING
/ALE/GRID/STANDARD
/ALE/GRID/ZERO
/ALE/LINK/OFF
/ALE/LINK/ON
/ALE/LINK/VEL
/ALE/MUSCL/OFF
/ALE/OFF
/ALE/ON
/ALE/SOLVER/FINT
/ALE/SUPG/OFF
/ALESUB (Obsolete)
/ANIM/Eltyp/FORC
/ANIM/Eltyp/Restype
/ANIM/Eltyp/TDET
/ANIM/BRICK/DAMA
/ANIM/BRICK/Restype
/ANIM/BRICK/TDEL
/ANIM/BRICK/TENS
/ANIM/BRICK/TENS/DAMA
/ANIM/BRICK/VDAMi
/ANIM/CUT/1 (Obsolete)
/ANIM/CUT/2 (Obsolete)
/ANIM/CUT/3 (Obsolete)
/ANIM/DT
/ANIM/GPS/STRAIN/TENS
/ANIM/GPS/STRESS/TENS
/ANIM/GPS1
/ANIM/GPS2
/ANIM/GZIP
/ANIM/KEEPD (Obsolete)
/ANIM/LSENSOR
/ANIM/MASS
/ANIM/MAT
/ANIM/NODA
/ANIM/SENSOR
/ANIM/SHELL/DAMA
/ANIM/SHELL/EPSP
/ANIM/SHELL/FLDF
/ANIM/SHELL/FLDZ
/ANIM/SHELL/IDPLY
/ANIM/SHELL/IDPLY/DAMA
/ANIM/SHELL/IDPLY/EPSP
/ANIM/SHELL/IDPLY/PHI
/ANIM/SHELL/IDPLY/Restype
/ANIM/SHELL/NXTFACTOR
/ANIM/SHELL/PHI
/ANIM/SHELL/Restype
/ANIM/SHELL/SIG1H
/ANIM/SHELL/SIG2H
/ANIM/SHELL/TDEL
/ANIM/SHELL/TENS
/ANIM/TITLE
/ANIM/VECT
/ANIM/VERS
/ATFILE
/BCS/ALE
/BCS/LAG
/BCS/ROT
/BCS/TRA
/BCSR/ALE
/BCSR/LAG
/BCSR/ROT
/BCSR/TRA
/DAMP
/DEL
/DEL/Eltyp/1
/DEL/INTER
/DELINT
/DT
/DT/AIRBAG/Keyword3
/DT/ALE
/DT/AMS
/DT/CST_AMS
/DT/Eltyp/Keyword3/Iflag
/DT/FVMBAG/Iflag
/DT/GLOB/Iflag
/DT/INTER/Keyword3/Iflag
/DT/NODA/Keyword3/Iflag
/DT/SHNOD/Keyword3
/DT/SPHCEL/Keyword3
/DT/THERM
/DT1/BRICK/Keyword3/Iflag
/DT1/SHELL
/DT1TET10
/DTIX
/DTSDE
/DYNAIN/DT
/DYNAIN/SHELL/STRAIN/FULL
/DYNAIN/SHELL/STRESS/FULL
/DYREL
/DYREL/1
/END/ENGINE
/FUNCT
/FVMBAG/MODIF
/FXINP
/H3D/BEAM
/H3D/COMPRESS
/H3D/DT
/H3D/LSENSOR
/H3D/NODA
/H3D/PART
/H3D/RBE2/SINGLE_PART
/H3D/RBE3/SINGLE_PART
/H3D/RBODY/SINGLE_PART
/H3D/QUAD
/H3D/SHELL
/H3D/SOLID
/H3D/SPH
/H3D/SPRING
/H3D/TITLE
/H3D/TRUSS
/IMPL/AUTOSPC
/IMPL/BUCKL/1
/IMPL/BUCKL/2
/IMPL/CHECK
/IMPL/DIVERG/n
/IMPL/DT/1
/IMPL/DT/2
/IMPL/DT/3
/IMPL/DT/FIXPOINT
/IMPL/DT/STOP
/IMPL/DTINI
/IMPL/DYNA/1
/IMPL/DYNA/2
/IMPL/DYNA/DAMP
/IMPL/DYNA/FSI
/IMPL/GSTIF/OFF
/IMPL/INTER/KCOMP
/IMPL/INTER/KNONL
/IMPL/LBFGS/L
/IMPL/LINEAR
/IMPL/LINEAR/INTER
/IMPL/LRIGROT
/IMPL/LSEARCH/OFF
/IMPL/LSEARCH/n
/IMPL/MONVOL/OFF
/IMPL/NCYCLE/STOP
/IMPL/NONLIN
/IMPL/NONLIN/SMDISP
/IMPL/NONLIN/SOLVINFO
/IMPL/PREPAT
/IMPL/PRINT/LINEAR
/IMPL/PRINT/NONLIN
/IMPL/PSTIF/OFF
/IMPL/QSTAT
/IMPL/QSTAT/DTSCAL
/IMPL/QSTAT/MRIGM
/IMPL/RREF/INTERF/n
/IMPL/RREF/LIMIT
/IMPL/RREF/OFF
/IMPL/SBCS/MSGLV
/IMPL/SBCS/ORDER
/IMPL/SBCS/OUTCORE
/IMPL/SHPOFF
/IMPL/SHPON
/IMPL/SINIT
/IMPL/SOLVER
/IMPL/SPRBACK
/IMPL/SPRING
/INCMP (Obsolete)
/INIV/AXIS
/INIV/AXIS/Keyword3/1
/INIV/AXIS/Keyword3/2
/INIV/ROT
/INIV/ROT/Keyword3/1
/INIV/ROT/Keyword3/2
/INIV/TRA
/INIV/TRA/Keyword3/1
/INIV/TRA/Keyword3/2
/INTER
/KEREL
/KEREL/1
/KILL
/MADYMO
/MADYMO/ON (Obsolete)
/MON
/NEGVOL
/OUTP
/OUTPUT/LSENSOR
/PARITH
/PRINT
/RAD2RAD/ON
/RBODY
/RFILE/n
/RFILE/OFF
/REPORT
/RERUN
/RUN
/SHSUB
/SHVER/V51 (Obsolete)
/STATE/BEAM/AUX
/STATE/BEAM/FULL
/STATE/BRICK/AUX/FULL
/STATE/BRICK/EREF
/STATE/BRICK/FAIL
/STATE/BRICK/ORTHO
/STATE/BRICK/STRAIN/FULL
/STATE/BRICK/STRAIN/GLOBFULL
/STATE/BRICK/STRES/FULL
/STATE/BRICK/STRES/GLOBFULL
/STATE/DT
/STATE/INIMAP1D/Keyword3
/STATE/INIMAP2D/Keyword3
/STATE/LSENSOR
/STATE/NO_DEL
/STATE/NODE/BCS
/STATE/NODE/TEMP
/STATE/NODE/VEL
/STATE/SHELL/AUX/FULL
/STATE/SHELL/EPSP/FULL
/STATE/SHELL/FAIL
/STATE/SHELL/ORTHL
/STATE/SHELL/STRAIN/FULL
/STATE/SHELL/STRAIN/GLOBFULL
/STATE/SHELL/STRESS/FULL
/STATE/SHELL/STRESS/GLOBFULL
/STATE/SPRING/FULL
/STATE/STR_FILE
/STATE/TRUSS/FULL
/STOP
/STOP/LSENSOR
/TFILE
/TH/VERS
/THERMAL
/TITLE
/UPWIND (Obsolete)
/UPWM/SUPG (Obsolete)
/UPWM/TG (Obsolete)
/VEL/ALE (Obsolete)
/VEL/ROT
/VEL/TRA
/VERS
