/GRBEAM
Block Format Keyword Beam Groups
Input Type Keywords: Beam Group
Keyword
Input Type
/GRBEAM/BEAM
Beam numbers
/GRBEAM/BOX or /GRBEAM/BOX2
Box
/GRBEAM/GEN_INCR
Generate list by increment
/GRBEAM/GENE
List of beams with generation
/GRBEAM/GRBEAM
Beam groups
/GRBEAM/MAT
Material
/GRBEAM/PART
Part
/GRBEAM/PROP
Property
/GRBEAM/SUBMODEL
Submodel
/GRBEAM/SUBSET
Subset
  1. A beam group is a set of beams (only). It can be defined by a list of:
    • beam ID
    • entering a first and last beam ID range which defines the group
    • subsets or parts (all beams belonging to the listed subsets/parts are included)
    • submodels (all beams defined in the listed submodels are included)
    • property sets or materials (all beams having those Property Type's/MID's are included)
    • beam groups
    • a box (all beams within a defined box are included)
