/GRSH3N
Block Format Keyword Describes the 3 node shell groups.
Input Type Keywords: 3 Node Shell Group
Keyword
Input Type
/GRSH3N/BOX or /GRSH3N/BOX2
Box
/GRSH3N/GEN_INCR
Generate list by increment
/GRSH3N/GENE
List of 3 node shells with generation
/GRSH3N/GRSH3N
3 node shell groups
/GRSH3N/MAT
Material
/GRSH3N/PART
Part
/GRSH3N/PROP
Property
/GRSH3N/SH3N
3 node shell numbers
/GRSH3N/SUBMODEL
Submodel
/GRSH3N/SUBSET
Subset
  1. A 3 node shell group is a set of 3 node shells (only). It can be defined explicitly by a list of:
    • 3 node shell ID
    • entering a first and last 3 node shell ID range which defines the group
    • subsets or parts (all 3 node shells belonging to the listed subsets/parts are included)
    • submodels (all 3 node shells defined in the listed submodels are included)
    • property sets or materials (all 3 node shells having those Property Type's/MID's are included)
    • 3 node shell groups
    • a box (all 3 node shells within a defined box are included)
  2. The 3 node shell groups are used to define sections, TH output.
  3. The 3 node shell groups cannot contain 4 node shell elements (use /GRSHEL instead).
