/GRTRIA
Block Format Keyword Describes a group of 3 node solid elements.
Input Type Keywords: 2D Solid Triangle Group
Keyword
Input Type
/GRTRIA/BOX or /GRTRIA/BOX2
Triangles from box identifiers
/GRTRIA/GEN_INCR
Generate list by increment
/GRTRIA/GENE
Triangles with generation (identifier range)
/GRTRIA/GRTRIA
Triangles using other group identifiers
/GRTRIA/MAT
Triangles from material identifiers
/GRTRIA/PART
Triangles from part identifiers
/GRTRIA/PROP
Triangles from property identifiers
/GRTRIA/SUBMODEL
Triangles from submodel identifiers
/GRTRIA/SUBSET
Triangles from subset identifiers
/GRTRIA/TRIA
/TRIA identifiers
  1. A 2D solid triangle is a set of /TRIA elements (only). It cannot contain any other type of element.
