Lines
Block Format Keyword
Input Type Keywords
Keyword
Input Type
/LINE/SEG
Segments
/LINE/SUBSET
Subset
/LINE/SUBMODEL
Submodel
/LINE/PART
Part
/LINE/MAT
Material
/LINE/PROP
Property
/LINE/GRTRUS
Groups of trusses
/LINE/GRBEAM
Group of beam
/LINE/GRSPRI
Group of springs
/LINE/LINE
Lines
/LINE/SURF
Surface
/LINE/EDGE
Edges of the Surfaces
/LINE/BOX or /LINE/BOX2
Box
  1. A line is a set of 2-node segments and can be defined:
    • explicitly, with segment connectivity
    • by box
    • by subsets, parts, properties or materials (all trusses and beams belonging to these entities are used to define the line)
    • by submodels (all trusses, beams and springs belonging to parts defined in the specified submodels are used to define the line)
    • by truss, beam or spring groups
    • by a surface (all lines of the surface are used)
    • by edges (edges of the surfaces are used)
    • with other lines
