/PROP/INJECT1
Block Format Keyword Describes mass injected for each constituent gas.
/PROP/INJECT1/inject_ID/unit_ID | |||||||||
inject_title | |||||||||
Ngases | Iflow | AscaleT |
mat_ID1 | |||||||||
mat_ID2 | |||||||||
etc | |||||||||
mat_IDN |
inject_ID | Injector
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
inject_title | Injector
Ngases | Number of
gases. (Integer) |
Iflow | Mass entity versus time
function input type flag.
(Integer) |
AscaleT | Abscissa scale factor for
time based functions. Default = 1.0 (Real) |
mat_IDi | Material identifier that
identifies the gas. (Integer) |
Mass of injected gas
versus time function identifier
(i=1,2...N). (Integer) |
Mass function scale factor
(i=1,2...N). Default = 1.0 (Real) |
or | |
Temperature of injected
gas versus time function identifier
Temperature function scale
factor (i=1,2...N). Default = 1.0 (Real) |
