Movable Solid Domain
Reposition or modify one or more parts between iterations of the simulation while keeping the geometry of the static solid and fluid domains constant. For example, you would designate the handle of a ball valve as a movable solid domain to run a simulation with the valve closed and another iteration with it open.
Note: If you only need to analyze the
fluid part without considering the surrounding geometry, then you can skip defining
the solid domain, and go directly to defining the fluid domain. The solver will
treat everything that doesn't have a boundary condition as in contact with a solid
part.
Before defining the movable solid domain, you need to define the static
solid domain.-
On the Fluids ribbon, select the Movable Solid Domain
tool.
- Select one or more parts that can be moved and modified before running a new iteration of the simulation.
- In the microdialog, assign a material.
