Run Iterations
Run iterations of the simulation by repositioning the movable solid domain.
Designate the movable solid domain.
- Select the movable solid domain.
- Press M to open the Move tool.
- Use the Move tool to translate and rotate the movable solid domain.
- Run an iteration of the simulation with the modified movable solid domain using CFD Quick Run or Custom CFD Run.
- For each new iteration, repeat the previous steps.
