Use to view the results of a porosity analysis. You can view shrinkage percentage, temperature evolution, solid fraction,
and solidification times for a selected run and load case.
Set up and view the results of a simple porosity analysis for casting.
Run a Porosity Analysis
Use to run a quick porosity analysis when designing metal parts that are casted. Then interactively view the results using the Analysis Explorer.
View Porosity Analysis Results
Use to view the results of a porosity analysis. You can view shrinkage percentage, temperature evolution, solid fraction, and solidification times for a selected run and load case.
