Couplers
Use the Couplers tool to couple the rotational or translational movements of connected parts. You can create two-way or three-way couplers.
Click the satellite icon that appears when you hover over the Couplers
tool to view a list of all joint couplers in your model.
A coupler allows you to specify a mathematical ratio which affects the movement of parts. It's useful for conceptual prototyping and general motion modeling. However, if you're interested in capturing detailed loading (like force distribution on gear teeth) or lash effects, these are better handled by motion contacts.
Valid Joint Types and Connections that Can Be Coupled
This tool works on a variety of connections (joints, supports, and implicit joints in motors, actuators, and springs). Flexible joints cannot be coupled.
Can Be Coupled* | Can't Be Coupled |
*In addition to list above, Inspire Motion also recognizes implicit joints such as the centerline joint of a motor or torsion spring, or a hole support with a translational degree of freedom.
Add/Edit Joint Couplers
Create or edit joint couplers between joints or at free joints.
Coupled joints must be rigid or virtual. Use the menu define the search parameters to only show rigid
joints or to force coupled joints to be rigid. You can also exclude design spaces
and ground parts from part selection.
- When using the guidebar navigation arrows during coupler creation, hold Ctrl when you click the Create button to create the coupler and automatically advance to the next candidate pair.
- An option to hide all couplers is available in the right-click context menu. In some models hiding all couplers may improve performance of the animation.
- If the movement of the motion analysis is opposite what you expected, change its direction. This can be done using the Reverse Direction option on the microdialog or Couplers table.
- Use the Flip Scale icon on the microdialog to swap the scale values for the coupler ratio.
- Use the Flip Entity Order property to change the order of the Entities list in the Property Editor. This also influences the appearance of curves in coupler plots.
- You may get an error message that the coupler requires a joint or support to
be rigid. To avoid this error, click
on the guide bar, and then select Force coupled joints to be rigid before creating the coupler, or change the joint to be virtual.
- Suppress/Unsuppress a coupler to understand its effect on your model. On the coupler, right-click and select Suppress. From the Model Browser or Table, right-click and select Unsuppress.
Additional Search Parameters
Click the menu on the guide bar to apply global options before
creating joint couplers.
- Only show rigid joints
- Enabling this option prevents flexible joints from being shown as candidates for selection when using the By Joints method.
- Only show grounded joints
- Enable this option so the candidates for selection will only display joints that are connected to ground when using the By Joints method.
- Exclude design spaces
- Design spaces are excluded from the find operation by default.
- Exclude ground parts/connections
- Enable this option to exclude ground parts and any connections to ground from the find operation.
- Force coupled joints to be rigid
- Enabling this option redefines flexible joints as rigid if they are included in a coupler.
Microdialog Options
Use the options in the microdialog to edit the coupler.
Figure 1. Couplers Microdialog
- Scale
- Enter scale parameters to define the coupler ratio.
- Reverse Direction
- Click the icon to reverse the direction of the coupler. You can also click the arrow on the coupler to change its direction.
- Set Joint Coupling
- Define whether the scale applies to translation or rotation.
- Reset Default Scales
- Click the icon to restore the default values.
- Flip Scale 1 and Scale 2
- Click the icon to swap the scale values.
Couplers Table
The Couplers table lists all of the joint couplers in your model including the entities in the coupler, whether the coupler is rotational or translational, and the scale factors.
To | Do this |
Rename a coupler | Select the cell in the table and then click again to make the field editable. |
Edit a parameter | Select the cell in the table and then click again to make the field editable. |
Sort a column | Click the column header. Click repeatedly to toggle between ascending and descending order. |
Add or remove columns | Right-click on a column header. |
