Altair Inspire checks for potential problems with the model before running an analysis or optimization and will suggest
solutions when problems are found.
A history of error messages, warnings, and informative messages are displayed and categorized in the Message Center.
Examples of messages include errors regarding failed parts during CAD import, construction history errors and information,
as well as status and run time information.
There are a number of problems that can prevent analysis or optimization from running successfully. The most common
reasons for failed runs are improperly defined load cases.
Note: Check the run.log file located in the File > Preferences > Inspire > Analysis > Run History Path. (The support team will want to review this
file.)
