Altair Inspire User Guide
2022
  1. Home
  2. Reference
    View the glossary, frequently asked questions, and errors and alerts.
  3. Errors and Alerts
    Altair Inspire checks for potential problems with the model before running an analysis or optimization and will suggest solutions when problems are found.
  4. Motion Errors and Alerts
    View suggested solutions for resolving Motion errors.
  5. Modeling Errors
    The section contains information about how to resolve modeling errors in Inspire Motion.
  • What's New
  • Get Started
  • Tutorials
  • Parametric Modeling
  • Structures
  • Motion
  • Design Explorer
  • Manufacture
  • Print 3D
  • Inspire Python API
  • Reference
  • Keyboard Shortcuts and Mouse Controls
Index
2022
  • What's New
    Discover new features and enhancements.
  • Get Started
    New to Inspire? Learn the basics here.
  • Tutorials
    Start using Inspire with our interactive tutorials.
    Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
  • Structures
    Set up your model and run a structural analysis or optimization.
  • Motion
    Set up and run a motion analysis, plot the results, and export the results.
  • Design Explorer
    Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method.
  • Manufacture
    Set up and run a basic porosity or thinning analysis.
  • Print 3D
    Preapare and run an additive manufacturing simulation, and export a file for 3D printing.
    Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
  • Reference
    • Frequently Asked Questions
      Got questions? We have answers!
    • Troubleshooting
      Need help troubleshooting a problem? Check out our troubleshooting topics.
    • Errors and Alerts
      • Message Center
        A history of error messages, warnings, and informative messages are displayed and categorized in the Message Center. Examples of messages include errors regarding failed parts during CAD import, construction history errors and information, as well as status and run time information.
      • Inspire Errors and Alerts
        There are a number of problems that can prevent analysis or optimization from running successfully. The most common reasons for failed runs are improperly defined load cases.
      • Motion Errors and Alerts
        • Modeling Errors
          • Model Contains No Active Parts
          • All Parts Are Grounded
          • Massless Part(s) Detected
          • Directional Conflict in Torsion Spring
          • Directional Conflict in Motor
          • Motor or Actuator Joint is Locked
          • Parts Defining Torsion Spring Are Grounded
          • Coil Spring Dimensions Are Not Realistic
          • Error Importing .csv File
          • Coupler Requires Joints to be Rigid and Active
          • Invalid Coupler
          • Actuator Joint Type Is Incorrect
          • Microseconds Time Units Not Supported for Motion Analysis
        • Run Termination Errors
          This section contains information about how to resolve run termination errors in Inspire Motion.
        • Information and Question Alerts
          This section contains information and question alerts in Inspire Motion.
    • Glossary
      View a list of glossary terms and definitions.
    Learn keyboard shortcuts and mouse controls for common operations.
2022
  1. Home
  2. Reference
  5. Modeling Errors
  • What's New
  • Get Started
  • Tutorials
  • Structures
  • Motion
  • Design Explorer
  • Manufacture
  • Print 3D
  • Reference
Index
Modeling Errors
  • Invalid Coupler
(c) Altair Engineering, Inc. All rights reserved.
