Connectors link points, edges, or faces to each other, and are shown as red lines radiating from a central point.
They are generally used to connect two parts together, or to apply a load or support at a distance.
Create and define connections such as fasteners, joints, connectors, spot welds, and
contacts.
Fasteners
Fasteners connect parts together without allowing movement at the hole location.
Joints
Use the Joints tool to connect parts together while allowing movement at the joint location.
Connectors
Connectors link points, edges, or faces to each other, and are shown as red lines radiating from a central point. They are generally used to connect two parts together, or to apply a load or support at a distance.
Spot Welds
Spot welds connect parts together by welding them at specific locations.
Contacts
Contacts indicate whether neighboring surfaces should be bonded, contacting, or have no contact.
