2022
Start using Inspire with our interactive tutorials.
Learn how to prepare, analyze, and export parts for 3D printing.
Discover new features and enhancements.
New to Inspire? Learn the basics here.
Get started learning how to adjust the view, move parts, run an optimization, and export files.
Learn how to create 2D sketches and parametric parts, prepare and simplify solid geometry, and model surfaces.
Learn how to create and modify PolyNURBS.
Define contacts, create fasteners, and connect parts with spot welds.
Run a baseline analysis and analyze a generated shape.
Learn how to run different types of optimizations and compare results.
Define joints and motion contacts, create motors and actuators, run a motion analysis and plot the results.
Create a design-of-experiments and explore the results.
Learn how to prepare, orient, slice, export, and analyze a part for 3D printing.
Learn how to prepare, simulate, and export an aerodynamic bracket design for 3D printing.
Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
Set up your model and run a structural analysis or optimization.
Set up and run a motion analysis, plot the results, and export the results.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method.
Set up and run a basic porosity or thinning analysis.
Preapare and run an additive manufacturing simulation, and export a file for 3D printing.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
